Latest post 06-22-2009 12:46 PM by burantek. 1 replies.
Page 1 of 1 (2 items)
  • 06-22-2009 12:33 PM
    My Beo5 Review
    Hello Everyone --
    Now that I have completed configuration of my Beo5 remote I wanted to offer my two cents on both the remote itself as well as the customization process.
    First, absolutely critical to my success was Keith Saunders and his Beo5 remote control programming service! I would not have been able to get my Beo5 uniquely configured to my requirements without his help (mainly due to outstanding software issues B&O should have addressed by now, and which Keith has already found workarounds.) In particular, the issues most difficult were being unable to have a “Repeat/Continous” function with RAW codes programmed to the Beo5 hard keys (Keith had to translate my Lintronic-captured RAW codes to NEC within the XML file, which was time consuming, and beyond my abilities.) Also, I was adding channel logos to my TiVo HD XML file, as well as utilizing the digits keys with other third-party equipment.
    Actually, there were many other hurdles Keith had to overcome in configuring my Beo5 to operate third-party equipment, to the point where I sincerely worried we would not be able to accomplish my customization. Happily, however, Keith was dogged in tackling each and every issue successfully!
    In short, I desired a Beo5 remote control that primarily operated third-party equipment and Keith was instrumental in getting me a Beo5 as unique for my needs as the key which unlocks my home.
    As for the Beo5 remote itself, in day-in and day-out operation it is SPECTACULAR! Compared to just about every other remote control it is superior, both in construction (solid and well-built) as well as operation.
    Make no mistake: the Beo5 is quite capable of replacing EVERY IR remote control out there! If B&O could work out the lingering configuration tool bugs as well as educate their dealer-network on the TRUE capabilities of their remote control I believe they would sell many, many more of them.
    As it is right now B&O should be extremely grateful Keith Saunders is out there helping get the word out on the vast capabilities of the Beo5 as well as graciously assisting users with customization and configuration!
  • 06-22-2009 12:46 PM In reply to
    Re: My Beo5 Review
    Lzrd15PosterChild:
    Agreed, and to add: look at something like Logitech does with their online Harmony programming!
    I would buy one! -and thanks to Keith, I would refer to it as the Keo5!
    BTW, welcome to the forum!
    • B&o bottle opener
