Latest post 06-23-2009 7:36 AM by MES. 2 replies.
Page 1 of 1 (3 items)
  • 06-22-2009 8:42 AM
    • MES
    • Not Ranked
    • Joined on 06-14-2009
    • Posts 4
    Speaker stands
    Would anyone know if a pair of s25's would fit on a pair of speaker stands for s30's ?
    Cheers
    Jim
  • 06-22-2009 3:27 PM In reply to
    Re: Speaker stands
    Does the S25 have bolt holes for the stands? I am not sure that it does. I would also suggest that the S25 needs really to be either shelf or wall mounted to boost the bass.
  • 06-23-2009 7:36 AM In reply to
    • MES
    • Not Ranked
    • Posts 4
    Re: Speaker stands
    Your right about the bolt holes and cheers for the advice.
    Jim
