Latest post 06-21-2009 1:58 PM by Friedmett. 1 replies.
Page 1 of 1 (2 items)
  • 06-21-2009 1:11 PM
    Beovision 8800 with Beo4 - HELP NEEDED
    Hello,
    I'd like to control my Beovision 8800 (and my Beocord VHS 91.2 + DVD 1 via the TV) with a Beo4 remote.
    Is that possible ?
    What would have to be changed or added to the Beovision 8800 (IR receiver etc...) ?
    Thanks for your help !
    Regards
    Pierre
    Filed under: ,
  • 06-21-2009 1:58 PM In reply to
    Re: Beovision 8800 with Beo4 - HELP NEEDED
    Very good question.
    What remote are you using at the moment?
    If you can control it with a Beolink 1000 then a Beo4 should be able to work.
    The one thing that I'm sure about is that the VHS 91.2 is able to work with a Beolink 1000.
    The sure thing is to update the Beovision to LX range and then there would be no problem.
