Latest post 06-25-2009 11:19 AM by symmes. 9 replies.
Page 1 of 1 (10 items)
  • 06-21-2009 5:21 AM
    • Corvin
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Australia
    • Posts 124
    Album Art?
    After finding one of my album art unacceptable, I scanned the cover in high definition. I then replaced all the art in the folder for the album on the BS5 with this art.
    When i view the album on the BS5 it still appears to be the old poor quality artwork.
    Has anyone got an idea why?
  • 06-21-2009 6:45 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Re: Album Art?
    Which file type do you use?
    In WMA and MP3 you can embed the cover into the file, that means it does NOT matter which album cover you have inside that folder.
    What program do you use for that?
    - Beoplayer
    - iTunes
    - Windows Media Player
  • 06-21-2009 8:22 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: Album Art?
    I am using WMP to rip in WMA lossless.
    I am placing a JPG in the album folder labeled Folder.jpg.
  • 06-22-2009 4:08 AM In reply to
    Re: Album Art?
    Corvin, try and scan your WMA files with Mp3tag, it will show inbedded album art and you can remove them leaving BS5 to use the folder.jpg
    http://www.mp3tag.de/en/
  • 06-22-2009 6:15 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: Album Art?
    mhampen:
    WOW learnt spomething new today. I was not aware that WMA embeded the artwork. A bit of a job ahead of me but thankyou so much, the BS5 looks so much better with good artwork.
    Much appreciated.
  • 06-22-2009 8:57 AM In reply to
    Re: Album Art?
    You are wellcome allways good to learn something Big Smile
    I think your can switch of WMP embedding or via WMP delete the coverart for whole album at one time
    Actually I have some CD's like hits from 60's and wanted to embed the coverart per track from the original album, but BS5 only takes the embedded coverart from track 1 in a music folder - so that could not be done unless I create seperate folder for each track Confused
    - maybe this will be changed in an update!
  • 06-22-2009 8:58 PM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: Album Art?
    MicTheCat:
    At least i can select the whole album in mp3tag and delete the embeded art. I would not like to do it track by track.
    What beats me is why only some of the albums had embeded coverart. Hmm
  • 06-23-2009 2:55 AM In reply to
    Re: Album Art?
    Corvin:
    Did you rip everithing using WMP?
  • 06-23-2009 8:48 AM In reply to
    • Corvin
    • Australia
    • Posts 124
    Re: Album Art?
    Yes, i went through my whole library and ripped them with WMP.
    Well almost all still have about 20 to go.
  • 06-25-2009 11:19 AM In reply to
    • symmes
    • Top 200 Contributor
    • Joined on 04-21-2007
    • Freedonia
    • Posts 290
    Re: Album Art?
    MicTheCat:
    Thanks for that tip!  Works perfectly, and because you can update the whole album at one time, not nearly as daunting a task as I had feared.
    Ray
