Latest post 06-21-2009 10:47 AM by bayerische. 3 replies.
Page 1 of 1 (4 items)
  • 06-20-2009 12:23 PM
    Connections and options ETC...
    Hi guys.
    I hope you can help me,
    Think I'll get my BV5 on wednesday next week, and I'm wondering about the connections.
    Also have an BS9000 in the same room, and I'm also getting a DVD1.
    I want them all hooked up, getting surround from my Beolab 5's, wishing to keep feeding the Beolab 5's the digital channel while listening to CD's.
    So how should these bee connected and optioned?
    Asking in advance.
    Andreas
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 06-20-2009 5:45 PM In reply to
    • Sal
    • Top 200 Contributor
    • Joined on 04-30-2007
    • Indianapolis, USA
    • Posts 261
    Re: Connections and options ETC...
    I have the same (if not much much cheaper system in my home) BS9000 to a BV8... the only wire out of the BS9000 (apart from the power cable) is a masterlink cable connected to the television. If no speakers are connected to your BS9000 (all speakers connected to the BV5), the BS9000 should be option 0 (it's IR eye is OFF), and the TV which would be the system master would be Option 2. Hope this helps. Sal
    Love B&O, but no longer addicted.
  • 06-20-2009 5:50 PM In reply to
    • Sal
    • Indianapolis, USA
    • Posts 261
    Oops, neglected to address the BL5 with a digital connection to the sound system. Looking at the BL5 guide, page 9 has a diagram which illustrates an ML connection from a BV5 to a BS9000, with a digital out from the BS9000 to one BL5, and another digital cable from the out of one speaker to the IN of the last speaker. I would imagine that the system would sort out what sound goes where. Sal
  • 06-21-2009 10:47 AM In reply to
    Sal:
    Thanks for the help Sal! Yes -  thumbs up
    -Andreas
