Latest post 06-19-2009 2:42 PM by Medogsfat. 1 replies.
Page 1 of 1 (2 items)
  • 06-19-2009 12:33 PM
    Connect BO tuner to Harman Kardon CD Player
    Hey there,
    I was wondering if you could help me. I need to connect my old beomaster 5500 to my Harman Kardon FL 8380.
    I'm not sure if it is even possible, but I hope it is.
    Any suggestions?
    Oh and please, explain things slowly, because I know almost nothing about audio and all the terminology.
    Thanks in advance!
    Dyakovlev0
  • 06-19-2009 2:42 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Connect BO tuner to Harman Kardon CD Player
    Hi and welcome to Beoworld. Smile
    Assuming the Harman Kardon FL 8380 CD player has RCA/Phono outputs it should plug straight into the CD input of the beomaster 5500. If you look at the inputs of the beomaster you will see that below the 5 pin DIN socket there are also RCA/Phono sockets which were intended for exactly this type of application.
    Oh - unless the CD player has its own remote you won't have remote control function via the beomaster.
    Chris.
    EDIT :- I've just googled your CD player model and all you need is a male to male RCA/phono plug lead from the audio output of the CD player to the CD inputs as described above. BTW the beomaster 5500 is a nice amp.
