Latest post 06-23-2009 4:18 AM by cjfc. 7 replies.
Page 1 of 1 (8 items)
  • 06-19-2009 11:43 AM
    • cjfc
    • Not Ranked
    • Joined on 09-22-2007
    • Posts 45
    Masterlink query
    Hello all
    We are doing some renovations at home and therefore i need to move the beoport location. To do so I removed the masterlink cable for the beoport from the masterlink junction the installers had added for the ML cables going off to different rooms – when I say junction it’s simply the different wires in the ML cable soldered together as required and taped up.
    One I think I noticed was that all the blue/white wire and pink wires were connected together at the junction – what would be the reason for that?
    Also the three non-insulated metal wires running through each cable were also connected to each other – what are these wires used for?
    Christian
  • 06-19-2009 12:13 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Masterlink query
    Not sure about the blue/white and pink wires, but the 3 non-insulated wires are earth/ground (one for each bundle of wires within the cable) and are supposed to be connected together.
    Stan
  • 06-19-2009 12:14 PM In reply to
    The cable structure can be found in the ML handbook. The pink cables are the +ve supply voltage, the blue and white is referred to as ML-sense and the silver wires are shields.
  • 06-19-2009 12:29 PM In reply to
    • cjfc
    • Not Ranked
    • Posts 45
    Thanks for the replies.
    Did have a flick through the handbook but couldn't see why the two wires would be connected.
    Though all works so no problem really
    Christian
  • 06-20-2009 5:11 AM In reply to
    As far as I'm aware, ML-sense (blue-white) isn't actually used.
  • 06-20-2009 7:01 AM In reply to
    Blue abd Pink should be connected when done in this manner.  However if you ahve any real concerns (but you shouldn't) just use a masterlink junction box to make the connectioin.
  • 06-20-2009 9:55 AM In reply to
    • Tayne
    • Not Ranked
    • Joined on 05-31-2007
    • Posts 23
    when a run of masterlink cables reaches 20m it is nessasery to connect the pink to step the voltage up to maintain  correct operation. this is done inside a masterlink junction box. this is also the reason why it is not possible to purchase a 'pre made' masterlink cable woth plugs at each end that is longer than 20m.
  • 06-23-2009 4:18 AM In reply to
    • cjfc
    • Not Ranked
    • Posts 45
    Tayne:
    Makes sense, the cables run to the other rooms and probably reach the 20m mark.
    Due to moving the beoport i will need to create a new junction half way along one the longer wires - as this is probably only 5-8m further along do i need to step the voltage again at the new junction?
