Hi Keith
I replied but it appears you have not received, so here goes again.....
Thank you for the welcome and for the quick response. I am glad to hear the problem is not a common one and also happy that the safety circuitry is there.
The cable damage appears superficial, the insulation is deformed but no inner cores are exposed. Is it possible, this damage will cause the safety circuit to activate ?. If so, I would appreciate details (supplier, part No. etc ) so that I can replace.
To answer your Qs:
How often does the AVANT switch off ?
The Avant has switched off (and went to Standby) on two separate days, about 1 week apart.
a) the 1st occasion, it was 3 times in quick succession, each time all was ok on return
b) the 2nd occasion, it was twice and this time I lost the setup of SAT button
Each time, I powered down the Avant for safety. I invested in a surge protector when I first bought the Avant.
Other than the STB, is there anything else connected to the AVANT via SCART?
The Avant has VCR built in and a Pioneer DVD. Beo4 remote works these ok.
Both were purchased with the Avant and installed by the B&O Dealer
Btw, I have checked all scart connectors on the back of the Avant, they are pushed home ok.
Kind Regards
