Latest post 07-06-2009 3:14 PM by Loris. 8 replies.
Page 1 of 1 (9 items)
  • 06-19-2009 3:37 AM
    • Loris
    • Top 500 Contributor
    • Joined on 03-27-2009
    • Italy
    • Posts 92
    beogram 6000 problem
    I've bought a beogram 6000 from ebay, but the sensor/arm unit doesn't work: it doesn't go ahead and the arm lower even without the record. For what I understand the "servo" doesn't work. Seems everything else works. Any suggestion?
    Thanx
    loris
    ps I already have a 5005 but this turntable is in another league Smile
  • 06-30-2009 4:54 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: beogram 6000 problem
    Hi Loris,
    In the below post, and the linked posts, you will find just about all you need to know about repairing your BeoGram 6000.
    http://forum.beoworld.org/forums/thread/94148.aspx
    BTW, DO NOT remove your CD-4 Demodulator board - it also functions as an extremely high-quality RIAA amplifier, and you'd have to spend a small fortune on an aftermaket pre-amp to even approach its quality.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 06-30-2009 5:06 AM In reply to
    • Loris
    • Italy
    • Posts 92
    Thanx a lot. I'll read it carefully.
    Loris
  • 07-04-2009 5:36 AM In reply to
    • Loris
    • Italy
    • Posts 92
    well, I lubricated the important points and they seem to work well, I lowered the bearing spindle at the right height, and now the arm won't lower without a disc,  I realigned the motor and the belt stays in the middle of the pulley but.... the servo doesn't work. It doesn't travel a millimeter
    Any suggestion?
    Loris
  • 07-04-2009 9:52 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Have you tested the servo motor?
    Chris.
  • 07-04-2009 10:19 AM In reply to
    • Loris
    • Italy
    • Posts 92
    How do I test it ? Smile
    Is it this? The arm moves back and forward, lowers properly but then remains stuck in his position
    http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.PostAttachments/00.00.20.98.09/assembly.jpg
  • 07-04-2009 11:36 AM In reply to
    Loris:
    That's it. Since you can drive the arm both ways, the motor, its belt and the driver circuit should all be fine and operational. You probably have some kind of a problem in the shutter circuit, that is supposed to instruct the servo on how to track the record grooves. The light / shutter / sensor assembly is located under the pivot point of the arm. Looking at the quoted picture, if you peek from the right under there, do you see any sign of the bulb lighting? (or course, Dillen will soon arrive and tell us some versions use a IR light which you can't see Laughing )
    -mika
  • 07-04-2009 12:18 PM In reply to
    • Loris
    • Italy
    • Posts 92
    Thanx Mika, as soon as I can I'll take a look at it. I've seen the "adjustment of shutter" section in the manual and I'll check if everything is ok.
  • 07-06-2009 3:14 PM In reply to
    • Loris
    • Italy
    • Posts 92
    Well the "housing with lamp" ( n. 244 in the manual ) doesn't work. Can I get one somewhere ? Should I check if the power supply reaches the lamp? How? There is another lamp ( that works) inside the carrier. What is it for?
    If you're interested click here:
     http://forum.beoworld.org/forums/p/12646/94148.aspx#94148
