Hi Everyone,
A friend of mine moved a couple of months ago and as you can guess... the movers dropped it, broke the glass doors and some of the plastic shell. When they plugged it in, it shorted out. The insurance co. paid for a replacement (lucky him ...) . I asked a quote at B&O to have it fixed, but it was more than it was worth.
Now a couple of months later I was lucky to find some spare parts in the US. Cosmetically it looks like an ouverture again. The short was an easy enough fix by changing some caps, fuse etc. The unit powers up, responds to a beo4 and the tuner works. The tape deck is working without problems ...
Now my question : I was trying to get the laser to work. In the service manual there is a cd laser service code and when you press 1 the laser should come on. 2 switches it off etc.
Mine doesn't seem to light up when requested.
The pcb that controls the laser seems to be ok, so I think it is the laser itself. Can the laser be replaced or does the whole Cd laser/motor unit need to be replaced. Also, where (besides B&O) can I find these parts ? (Philips?)
Any info on this would be welcome. I know a little bit about electronics, but cd lasers leave me totally clueless ...lol
Also is there a kit available to change the polished metal parts and at what cost ? The ones on the machine are not too bad but if the price is ok I'll get it changed.
Also if anyone has a couple of spare doors for a beosound 4000/ouverture available, let me know.... I am almost done with figuring out the wiring for the movement for the doors ...
Any help would be greatly appreciated...![Smile](http://forum.beoworld.org/emoticons/01.gif)
