Latest post 06-17-2009 5:52 PM by Bv7Mk3. 0 replies.
Page 1 of 1 (1 items)
  • 06-17-2009 5:52 PM
    Is this the First?????
    I have a Beomaster 5 connected to a Bv7-40 which I use everyday which I think is brill and at the mo I have around 20 albums on the system just now and I listen between them and net radio.
    Yesterday eve I came home sat down turned on the Beomaster which started to play net music which I had clicked on and after around 30seconds the music track started to slow down then few sec's later speed up then go really slow again.
    I turned off the unit yesterday then back on and it just hanged on the choices screen so switched off over night,today it does not get that far so will ring the shop tomorrow thursday.
    Anyone had a similar problem?
    Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
