Latest post 06-19-2009 10:37 AM by Die_Bogener. 4 replies.
Page 1 of 1 (5 items)
  • 06-17-2009 7:49 AM
    MX4000 problems
    The problem is that the picture tube seems to produce a electrical/buzzing sound. It is not to loud, but my old MX3500 did not have the problem.
    Is this problem easy to fix?
  • 06-17-2009 1:27 PM In reply to
    Re: MX4000 problems
    Yes. Remove the rear cover, switch off all lights, start your MX and look at the mainboard from underneath. You will probably see a light called C102 ;)
  • 06-18-2009 4:05 AM In reply to
    Re: MX4000 problems
    Thanks for the reply. I am not very technical can you tell me exactly wat C102 is and wat needs to be done?
    thanks a lot for your time.
  • 06-18-2009 5:55 PM In reply to
    Re: MX4000 problems
    Hi, this link can help you...
    http://forum.beoworld.org/forums/t/24571.aspx
    Thanks to Die_Bogener for this verry good help for rebuild MX...
    Best,
    Daniel
  • 06-19-2009 10:37 AM In reply to
    Re: MX4000 problems
    I really ment a spark next to the cap C102. You can see and hear it in the dark, that is no joke!
    Sounds like Bzzzbbbzzbbzzzzz are bad solders around the high frequency of the transformer or the big blue plastic caps. It really makes sense to watch these parts in the dark. These sparks are visible.
