I am in the procces of buying a Mac mini to use as a media center in my living room.
I would very much like to control it with a BEO4 but my old LX5000 television doesn't have a lot of STB options (if any).
When searching these forums i found that the Irtrans/ired solution might be the best approach.
But some things are a little unclear and i would very much like to hear other peoples experience with this solution.
So to sum up i have the following questions:
1: Will the ir trans box communicate with the mac mini through the USB/ethernet interface or via. the IR eye on the mac?
2: USB or ethernet version? Pros and Cons? I found some posts about it but they were from 2007 so things might have developed since then.
3: If i like to get a non B&O television later I would very much like to be able to control it vith the BEO4. Will this be possible with both the USB and the ethernet version? Should i get extra IR blasters for this to work?
4: Any other things to consider?
Thanks in advance
