dkresz:
puncher:
If both 1. & 2. are lossless conversions, to what do you attribute the apparent superioity of the wma lossless file?
Primarily, on a blind test - comparing the same song at the same (lossless) resolution on the BM5. I encourage you to do the same.
Now to the speculative part: one is (mainly) Mac and the other is Windows? The codecs have diiferent encryption / decryption algorithms that are affected by the platform? BM5, being Windows XP Embedded, may be fine-tuned for WMA and WAV playback ? It will be interesting to re-run the same comparison test when the BM5 / BS5 software gets upgraded to officially support AAC lossless...
I have to toss my foot in here.
All that (and the rest of your posts on this subject) is emphatically wrong.
If in doubt, find an uncompressed track, say, a wave-format file. Md5 checksum it.
Convert the file to Aiff and then back to wave. Md5 checksum it.
Convert the file to ALAC (Apple Lossless) and then back to wave . Md5 Checksum it.
Convert the file to flac and then back to wave. Md5 checksum it.
Convert the file to WMA lossless and then back to wave. Md5 checksum it.
You will find that they ALL have the exact same checksum. The reason for this is, naturally, that they ALL are lossless containers, containing the exact same PCM-data.
As I said in the other thread: Any difference you hear is imaginary.
b
