Latest post 06-15-2009 9:16 PM by auric. 2 replies.
Page 1 of 1 (3 items)
  • 06-14-2009 10:15 AM
    BC 9000 problems...........
    Had a lot of fun with it, but now it no longer plays.     Within the last couple of weeks, ff worked on and off, rw had less issues but still didn't work all the time.
    Within the last 3 days, play started working on and off, finally today, it no longer works, the unit powers on,
    I knew beforehand the day would come when my bc9000 would need refurbishing and full overhaul.   Is it about time to send it sound-smith for $690 full overhaul?
  • 06-14-2009 3:10 PM In reply to
    Re: BC 9000 problems...........
    It depends on how much you want to spend on it.
    Usally fast forward and reverse needs to be lubricated when moving gets slow.
    The drivebelts needs to be  fresh too and if they are still the originals mounted I would highly recommend to get in touch with Dillen here.
    Opening a Beocord 9000 is a very simple thing to do. Losen the 2 screws, one on each right and left side on the back of the Beocord, and open the top.
    The drive unit is hold with 3 screws and 2 wire plugs which is also simpel to remove.
    When the unit is out you can lubricate the unit and mount the new drivebelts.
    The electronics of Beocords are pretty long lasting in general and as they are pretty much obsolete they have alot of life as 90% of the cassete people have moved on to other formats. The most of them have not run as much as Beomaster or Beogram CD. Beograms get used until they give up. Beocords? Great sounding machines for little money.
  • 06-15-2009 9:16 PM In reply to
    Send it to Atlantic-Systems in Hanover MA. I'm sure it won't cost nearly that much!
