Latest post 07-03-2009 5:04 AM by beolife. 2 replies.
Page 1 of 1 (3 items)
  • 06-14-2009 8:38 AM
    Link problems & does a AV2 expander work with a Beosystem 2
    Hi Guys,
    I got a link problem, My avant which is the slave has started to play up, the stand by led is flashing quite fast. I have tried usual things like resetting etc, I can access the CD/Radio from the Beomaster 7000 from both the master (Beosystem 2) & the avant, but I cannot access the sources on the master like DVD etc, the whole system seems to freeze. I have reset the options & have checked the cables.
    Here are the error messages from both of them
    Avant (slave)
    Clock error Comm, fail- there are no tv or ML/SL errors
    BS2 (Master)
    Last Tv errror 0406 22-2A
    Last ML/SL error TD
    Hope someone has got an idea.
    Also is it possible to use an AV2 Expander with the Beosystem 2 to provide more inputs mainly for games consoles.
    Thanks in advance
    Simon
  • 07-01-2009 4:14 PM In reply to
    Re: Link problems & does a AV2 expander work with a Beosystem 2
    Simon,
    Sorry I missed your posting and you had to prompt me.
    Let me take the easy bits first -- The "Last TV error 0406 22-2A" is nothing to do with your problem and is a Teletext error caused either by a poor analogue signal or you don't have an analogue aerial plugged in.
    The other errors of Clock comm failure and the TD error make it clear that a Masterlink data signal is held low possible shorted to a ground screen or another signal.
    You should carefully check all your Masterlink connections by unpluging them all from the B&O products and first check that no two signals are shorted together by using a multi-meter.
    Regards Keith....
  • 07-03-2009 5:04 AM In reply to
    Thanks Keith,
    Will troubleshoot over the weekend.
