Latest post 06-13-2009 4:49 PM by Medogsfat. 3 replies.
Page 1 of 1 (4 items)
  • 06-13-2009 1:47 PM
    Beomaster 5000 controlled with MCP 7700 not working(?)
    Hello guys
    I have a Beomaster 5000 which came with both Master Control Panel (MCP) 7700 and Master Control Panel 5000.
    The MCP 5000 works fine with the BM 5000, but I can't control any functions with the MCP 7700. I have checked the IR LED's and they seem to be transmitting (all of them, checked with scope).
    The MCP 7000 keeps saying "No Transmission" no matter what I do.
    Any ideas? Could it be related to the two-way transmission in any way?
    PS: The BM5000s fault was in the power amplifier output (shorted power transistor).
    Kind regards, Mr. Kim Voss Schrader of Denmark
  • 06-13-2009 2:02 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Beomaster 5000 controlled with MCP 7700 not working(?)
    Hi and welcome to BeoworldSmile
    There is probably nothing wrong with the MCP7700 - it just won't work with the beomaster 5000 as it uses different codes. The MCP7700 was designed to be used with the Beocenter 7700.
    Chris.
  • 06-13-2009 4:11 PM In reply to
    Hello
    I probably should have figured that out by my self, but thanks anyway. I'm fixing the BM5000 for a customer, and when someone delivers a remote (two in this case) I'm expecting them to work with the brought tuner.
    Thanx :)
    Kim
  • 06-13-2009 4:49 PM In reply to
    • Medogsfat
    • Posts 4,045
    I see why you got confused now. Typical B&O though - sensible assumptions will always land you in troubleSmile
    Chris.
