Hello,
Thank you tournedos, the resistance got no inscription at all so now it's easy to find the missing one.
Now i take my time to buy good new parts. (SCR for caps)
I' ll change the plug for banana compatible, new cables..
In parallele i search in the net an amp to drive the S75, can you tell me the ideal power needed ?
Some brands working well with this speakers ? Listen jazz, seventie's, eighty's,bossa......
I read i don't no where Harman Kardon be a good combo. I see an Harman/Kardon HK6500 for 100/120€.
Thanks.
