1st March February 2012
Latest post 06-15-2009 2:42 PM by Tillquist. 28 replies.
06-10-2009 2:36 PM
Friedmett
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.29.73/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 04-28-2007
- Herning, Denmark
- Posts 840
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Stacking a Beosystem 5000/5500/6500 and 7000
As I recall there was at least one thread like this but was that on the old forum?
Well as I'm a recently new Beosystem 6500 owner I would like to hear your thoughts of the ideal way to stack it.
The system has the following units:
Beomaster 6500
Beocord 6500
Beogram CD 6500
Beocord 5500
Alex
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.67/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- Bath & Cardiff, UK
- Posts 2,990
Re: Stacking a Beosystem 5000/5500/6500 and 7000
Beogram Beomaster Beogram CD Beocord
The amplifier is often put nearer the top as it can stop them overheating if you're playing at very high volumes. I've not had any problems with this, and would keep mine in bottom if I had four units to stack (I only have two). If you can keep the amp on bottom (ie, you don't listen at high volumes much, you're driving active speakers or something large/easy to drive) then I would.
Weekly top artists:
![](http://imagegen.last.fm/lastfmblue/artists/3/haircutalex.gif)
j0hnbarker
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.31/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- LS28/GB
- Posts 2,002
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
I had my 5000 system 2+2 with Beomaster on top of Beocord, and Beogram on top of Beogram.
Medogsfat
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.35/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
As you have 2 beocords I would place these at the bottom with CD above & finally the Beomaster on top - as Alex said due to the heat generated if giving it some whelly.
Chris.
Friedmett
- Herning, Denmark
- Posts 840
It's nearly like that at the moment.
I just have to move the Beocord 5500 a bit lower.
The Beocord 5500 was an afterthought as I ran into it in a secondhand store. Cheap, very good condition and working 100%. I could not say no.
I use Beovox S80.2 until I get enough cash for a pair of Beolab Penta MKIII. There is such a pair in a shop here and they are very cool.
Volume is not on high side but I will put the Beomaster 6500 near the top.
beocool
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.55.29/avatar.jpg)
- Joined on 10-17-2007
- the Netherlands
- Posts 5,514
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
My 7000 used to be stacked 2+2, Beogram on top of Beomaster and Beogram CD on top of Beocord. Unfortunately my Beocord 7000 is broken and I will get a new on at some point. Right now it's Beogram, Beogram CD and Beomaster. I never play at high volume by the way.
Puncher
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.46/avatar.jpg)
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
Mine is in a 4 high stack at the moment (BG5000 on top, BM5000, CD50, BC5000) although I always preferred the 2x2 layout when we had the bench space. I've never seen a 4x1 (akin to a 4500 system) but it'd be interesting if you had the space.
Jandyt
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.58/avatar.jpg)
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
Since there is not a Beogram, I would have the Beomaster on top so as to get to the connections easily. The others are unimportant I believe. Though, aesthatically, I would keep the Beocords together.
Andy T.
burantek
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.31.44/avatar.jpg)
- Joined on 05-04-2007
- SE USA
- Posts 6,214
i have a 3x2...
tournedos
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.61.93/avatar.jpg)
- Joined on 12-08-2007
- Finland
- Posts 5,808
From bottom to top, mine are cord, CD, master and obviously gram on the top
If I had the space, I'd lay them all flat though. I have actually entertained the thought of building a wall shelf to take them like that (as invisible as possible, like the Beogram shelves are).
cooldude
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.75.69/avatar.jpg)
- Joined on 03-14-2008
- Posts 971
Mine is a 2+2 setup with the beocord and beogram cd on the bottom and the beomaster and beogram deck on top.
I had to put the beomaster on top as it was getting fairly hot in mcl setup.
Love to see other peoples pics of their setups and I'll try to post one later myself ...
cooldude
- Posts 971
soundproof:
Agree with that, Peter - and it's smart to put the Beomaster on top of the CD-player. Putting weight on the CD-player helps reduce any vibrations in that unit. This is in my home-office.
Love that setup and you are right I'll try to put the beomaster on top of my cd player and see if it helps as my 6500 cd player is temperamental at best.
Peter
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.26/avatar.jpg)
- Joined on 02-12-2007
- Posts 9,572
Actually when I had my 7000 set up, I had two Beocords on the bottom, the BeogramCD and the Beomaster on top and the Beogram LP on the wall bracket.
Xseries
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.51/avatar.jpg)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- Hampshire
- Posts 433
Beogram on top, the BM 7000 then casette player with the CD at the bottom - from memory I will now go and check (I was right)! The reason to have the casette player one up from the bottom is to stop it knocking things off when opening it! The CD player is only 1/3 of the width and slightly higher so it does not knock a record cleaning cloth off when opening!
I have always stacked them this way since my first BM 5000 system back in 1985!
This is also the way that nearly all the catalgoues show them (when stacked 1 above the other).
I dug out a Beosystem 5000 promotional brochure that shows them stacked in a variety of ways 1 1 2 (record deck on top), 2 1 1 (record deck at end), 1 3 (tape deck on tis own), 4 in a row (though the photo cut out at 3.25!) and also as two pairs with space between!
Interestingly the stack of 4 was BM, BC, CD50 and BG - but then these are photos for publicity rather than the real world with furnitre etc.
Brian
Jandyt
- Posts 13,004
Peter :
That's the answer if you have a Beogram. I could do with about 4 Beogram wall brackets of Steve (Sounds Heavenly)!
Peter
- Posts 9,572
The B&O recommended way from the top down for the 5000 system is:
Beogram 5000
Beomaster 5000
Beogram CD50
Beocord 5000.
It allows you to have all the units open but still easily access all the sources! The 5500 system rather spoilt this by the cassette being directly under the CD tray of the CD50, but this was rectified when the CD5500 was released as the tray moved to the other side!
henrik
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.77/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Stockholm, Sweden
- Posts 299
I used to have my 7000 on a large sideboard, and sometimes I'd rearrange the system. In fact, I think it looks stunning in 1x4, 2x2 and 4x1 combinations, each combination has its own visual advantages :-)
Nowadays the 7000 is placed on a tiny table, so 1x4 is the only option (see photo (yes, I really have to do something about that cable mess, haha)). As you can see, I have placed the beomaster between the beocord and the beograms, I think the displays line up really nice that way (see photo).
Friedmett
- Herning, Denmark
- Posts 840
![](http://i114.photobucket.com/albums/n277/Friedmett/Beosystem6500001-3.jpg)
Here is a recent picture. I think in order for the finish of the Beocord 5500 it will take the space at the bottom.
Yes I still got my Attyca II but one reason for the 6500 system was to save on space. My Beosystem 6000 and 8000 takes enough allready.
I might go with the stand designet for the 6500 someday and I think the Attyca will be sold.
Dave
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.88/avatar.jpg)
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
soundproof:
This is a really beautiful space and a great combination of new and classic.
Why are there so many pictures of wires being exposed though? It spoils the aesthetics of the beosystem... big time
henrik
- Stockholm, Sweden
- Posts 299
Dave:
Oh, I agree. In my case it's only a matter of time - I've made a kind of cable trap to hide the cables underneath the table leaving only one powercord and the speaker cable visible (but all put in one tube), I just haven't attached it to the table yet (I have to find a way to attach it without altering the vintage table)
Steve at Sounds Heavenly
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.34.84/avatar.jpg)
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Jandyt:
Hi Jandyt,
Funny you should mention that, I've just (last week) purchased a Beosystem 6500 from eBay to look into making wall bracket sets for the whole system. I currently have a house full of toddlers (well one, but she seems like a house full at times!) with sticky fingers and I would prefer to keep everything up on the wall out of harm's way.
I suspect that my initial Beogram wall bracket design will need a few alterations to make it suitable for housing any of the four items from a Beosystem 5000/5500/6500/7000 set, as weights and mounting points vary greatly.
If anyone is interested in these (no commitment is needed, I'm just looking gauge the level of interest), please drop me a line through the forum or via my sponsor link below.
Thanks, Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
