Latest post 06-08-2009 5:34 AM by wootha. 2 replies.
Page 1 of 1 (3 items)
  • 06-08-2009 4:40 AM
    • wootha
    • Not Ranked
    • Joined on 06-08-2009
    • Posts 3
    Front touch panel fell out of my Beomaster 4500!
    Has anyone had this problem? Or better still, fixed it? The front panel on my 4500 amp/tuner has become detached from the unit. It was attached with some sort of rubberised gasket, not glue, and I'm wondering how to reattach it. Any advice welcome.
  • 06-08-2009 5:02 AM In reply to
    Re: Front touch panel fell out of my Beomaster 4500!
    Very common problem.
    Just search "4500 glass" in the top R/H corner of this screen.
    You will be overwhelmed!!
    Regards Graham
  • 06-08-2009 5:34 AM In reply to
    • wootha
    • Not Ranked
    • Posts 3
    Many thanks for that quick response. You're right, I am. And to think here was me thinking I'm the only person in the world with this problem!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
