The cover is held in 4 places as shown below.
The correct way of opening the unit is to slip the tool or very thin flexible blade either side of the top of the battery compartment allowing the back to lift 1-2 mm, with both sides lifted a couple of milli metres, then insert the tool near the ear piece and the phone will come appart
