Latest post 06-21-2007 5:11 AM by beologisch. 7 replies.
Page 1 of 1 (8 items)
  • 06-02-2007 1:32 PM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    Bs 7000 start up volume
    Hi.
    When i start up my Bs 7000 the volume is too loud believe it or not.
    How do i set it to come on at a lower pre set volume everytime?
    Thanks for any help
    Fil
    Filed under:
  • 06-02-2007 1:41 PM In reply to
    Re: Bs 7000 start up volume
    Set the volume you require at start up and then press SOUND, STORE, STORE on the remote
    Regards Graham
  • 06-02-2007 8:27 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Sorry, had too much loopy juice, b ut Fil might have a Beo4.
    Adny T.
    Poor me, never win owt!
  • 06-03-2007 1:55 AM In reply to
    If he has, my recommendation is that he bins it and gets a beolink 1000!!!
    Regards Graham
  • 06-03-2007 4:01 AM In reply to
    You just need to add A.SETUP to the LIST. Get the sound to the volume you like, select A.SETUP, the press LIST and after BASS,TREBLE and LOUDNESS, you will get to S.STORE. Press GO and the levels are stored. Just checked using my 5500.
  • 06-03-2007 3:31 PM In reply to
    • Jandyt
    • Posts 13,004
    joeyboygolf:
    LaughingLaughingLaughing
    Andy T.
  • 06-20-2007 10:05 AM In reply to
    • Fil
    • Posts 90
    Hi guys.
    Thanks for the advice.
    However i neglected to say that it was linked to an Avant.
    That said , i done exactly as you said through the tv set up menu and hey presto.......................nice and quiet on start up!
    Thanks again
    Fil
  • 06-21-2007 5:11 AM In reply to
    joeyboygolf:
    LaughingLaughingYesLaughingLaughing
    Leon: Beoworld's First "First Prize" winner. "Carpe Diem et Dolce Far Niente"
