I have been using my apple tv successfully with my BV3 connected to the v.tape socket via scart (via converter) and it has been correctly displaying full wide screen when I switch to v.tape and overall really pleased with this set up.
However I have now added an ir splitter in order to control the ATV via the v.aux STB and although the control via the BEO4 is great, the picture format when I switch to v.aux is no longer fulll widescreen and I need to switch using the format 3 command. It seems strange that with the connection setting of v.tape I have no problem, but with v.aux I get this issue. I gain the control via BE04, but have the pain of needing to set the format correctly each time. Nothing else has changed, so does the BV3 assume that either v.tape is format 3 or that v.aux is not?
Any ideas on why this is happening or how to solve it greatly appreciated.
Another nice to have would be to be able to assign the v.tape button to v.aux rather than having to select v.aux via the list.
Thanks for any advice, Jon.
