Latest post 06-03-2007 5:51 AM by David. 5 replies.
Page 1 of 1 (6 items)
  • 06-02-2007 12:55 PM
    • David
    • Top 500 Contributor
    • Joined on 05-05-2007
    • England
    • Posts 128
    Beo4 and Sky+
    Hello,
    Which button on the Beo4 do I press to record a programme which is on Sky+?
     Have never known this I have always used the Sky remote and pointed it at the Sky box!
    Beolab 8000, Beolab 6000, Beolab 2, LG CX65, Beosystem 3, Beosound 9000, Beolab 3500
    Filed under:
  • 06-02-2007 12:59 PM In reply to
    • Top 75 Contributor
    • Joined on 04-01-2007
    • UK
    • Posts 970
    Re: Beo4 and Sky+
    GO RED
  • 06-02-2007 1:09 PM In reply to
    • David
    • England
    • Posts 128
    Re: Beo4 and Sky+
    Thanks for the info.
    Cheers,
    David.
  • 06-02-2007 2:09 PM In reply to
    • UK
    • Posts 970
    Re: Beo4 and Sky+
    my pleasure :-)
  • 06-03-2007 2:14 AM In reply to
    Re: Beo4 and Sky+
    David:
    Thanks for the info.Cheers,David.
    If you press MENU on your Beo4 you will see a menu pop up on the left hand side of your screen, that displays all the corrosponding Beo4 buttons preceded by MENU or GO to operate your Sky+.
  • 06-03-2007 5:51 AM In reply to
    • David
    • England
    • Posts 128
    Re: Beo4 and Sky+
    Thanks for that.Cheers.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
