Latest post 06-08-2009 3:17 PM by Keith Saunders. 6 replies.
Page 1 of 1 (7 items)
  • 06-03-2009 5:42 AM
    • k984942
    • Top 500 Contributor
    • Joined on 11-10-2008
    • London, UK
    • Posts 194
    Missing Functions
    Hi All,
    I've just taken my first steps into the fiasco that is Beo5 programming!
    So far all is well and I'm generally managing to get it into shape. However, I can't seem to figure out the following:
    1. How do I add a P. Mute button to one of the sources
    2. How do I switch the order of the pages that I'm presented with? At the moment when I press Virgin V+ the first screen is record, menu, V+, channel listing, etc etc. I would like the first few pages to be the channel listing then a page of all the other function buttons.
    3. How do I go about setting up Macros?
    Any advice is, as always, greatly appreciated
    32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
  • 06-04-2009 4:57 PM In reply to
    Re: Missing Functions
    Taking your questions in the same order here are my comments:-
    1. P.MUTE uses code 0:000:TV:PICTURE_TOGGLE and is in the IR list but does not come up when you type in PMUTE
    2. Click the EDIT tab and use the BUTTON CLIPBOARD to move (drag) buttons from page to page. In other words, if you want some from page 3 on Page 1, then move them from page 3 to the clipboard, then go to page one and move (drag-n-drop) them to where you need them.
    3. Macros are a series of commands, you can add delays between commands if needed and if you right click on a button/icon you want a macro setup too. Click properties and then click the IR tab. Choose the command you wish to add and press add, then add the second and subsequent commands.
    Regards Keith....
  • 06-05-2009 1:40 PM In reply to
    Keith..
    I will have a command like this
    Format 0
    And then Sanyo ON-OFF (that you have done for 3:e party)
    How shall I do?
  • 06-08-2009 9:53 AM In reply to
    Not sure I completely understand your question.
    If you are asking:-
    Can I make a macro of "FORMAT 0" and Sanyo ON-OFF then the answer is YES
    In the Configuration Tool right click on the Sanyo ON-OFF button and then left click PROPERTIES then click tab IR
    In the Command name use PICTURE_FORMAT and press ADD
    Regards Keith....
  • 06-08-2009 11:24 AM In reply to
    Yes Keith you are right, but it dosent work
    When I save it and test it there is only "Format 0" left and Sanyo ir is goneConfused
  • 06-08-2009 11:37 AM In reply to
    OK got it worked now, BUT I can NOT change "ON-OFF" to lets say "Bio ON"
    Sanyo codes dissapeare!!
    I have the latest SW TOOL
  • 06-08-2009 3:17 PM In reply to
    Yes, there is a problem with the new version of the Configuration Tool with adding a second and subsequent command in several situations, so you may have to edit the XML file itself to add the requirements.
    I am currently compiling a list of issues found with the new version of the Configuration Tool and this is certainly one of them.
    Regards Keith....
