k984942:I have a few Avants and they all seem to show the same strange behaviour. They all select 16:9 (as WSS detection is set to on) when watching Virgin or DVD's, yet when watching normal analogue TV through their in built tuners they will never select full 16:9!
My avantDVD inbuilt analog tuner change the screen format automatically and always perfectly well among the 3 picture formats depending the analog tv broadcast picture format sent by my local tv provider.
When a tv broadcast is transmitted in 16:9 anamorphic format by my analog tv provider AND this transmission also has the picture format signal along with (TF1, France3, Arte, Direct8, NRJ12, ARD1, ZDF...etc) then my avant change automatically to "FORMAT 3" (widescreen); exactly in the same way when playing DVDs.
If the analog tv broadcast transmission is in 16:9 letterbox format AND the picture format signal is transmitted too (TSR1, TSR2, TCM, RSI1, RSI2, SF1, SF2...) then my avant change automatically to "FORMAT 2" (zoom).
Exactly the same happens with all 4:3 SD transmissions and the avant "FORMAT 1"...
It's absolutely essential that your analog tv local provider send you the correct PICTURE FORMAT SIGNAL INFO (aspect ratio) along with the tv channels image (in the same way that teletext info!) Only when the avant receives this picture format signal can change the screen format by itself.
In addition the HDR2 inbuilt analog tuner (VTUNER) works exactly in the same way!!! and changes automatically the screen format according to the analog tv broadcast aspect ratio... of course it works with all the recorded material too.
Hope this hepls.
Regards.
