Latest post 06-08-2009 9:58 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 06-03-2009 4:07 AM
    Problems with serialization and configuring P-and-P for all the fonts.
    Hi to everyone!
    I’m trying hard to enable the P-and-p for all the video fonts that are connected to Beo Vision 7-40 MKIII EU:
    TV – Beo Vision 7-40 MKIII EU
    DTV – DVB from BeoVision
    DVD - DVD from BeoVision
    DVD2 – Emtec Movie Cube
    V. Mem – Imagenio (PUC enabled)
    V. Aux – Nintendo Wii
    V.Aux 2 – Xbox 360
    When I’m at the EDIT of the configuration tool it seems that I’ve enabled P-and-p correctly, but I get the following error during serialization:
    ERROR: [1080] "ZONES\STANDARD\BEOVISION7-40\CAMERA\PANDP\DVD2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\DVD2\PANDP\CAMERA" not found
    ERROR: [1109] "ZONES\STANDARD\BEOVISION7-40\CAMERA\PANDP\V.AUX\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX\PANDP\CAMERA" not found
    ERROR: [1111] "ZONES\STANDARD\BEOVISION7-40\CAMERA\PANDP\V.AUX2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX2\PANDP\CAMERA" not found
    ERROR: [1157] "ZONES\STANDARD\BEOVISION7-40\DTV_DVB_HD_EU\PANDP\DVD2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\DVD2\PANDP\DTV_DVB_HD_EU" not found
    ERROR: [1186] "ZONES\STANDARD\BEOVISION7-40\DTV_DVB_HD_EU\PANDP\V.AUX\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX\PANDP\DTV_DVB_HD_EU" not found
    ERROR: [1188] "ZONES\STANDARD\BEOVISION7-40\DTV_DVB_HD_EU\PANDP\V.AUX2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX2\PANDP\DTV_DVB_HD_EU" not found
    ERROR: [611] "ZONES\STANDARD\BEOVISION7-40\DVD\PANDP\DVD2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\DVD2\PANDP\DVD" not found
    ERROR: [762] "ZONES\STANDARD\BEOVISION7-40\DVD\PANDP\V.AUX\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX\PANDP\DVD" not found
    ERROR: [768] "ZONES\STANDARD\BEOVISION7-40\DVD\PANDP\V.AUX2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX2\PANDP\DVD" not found
    ERROR: [888] "ZONES\STANDARD\BEOVISION7-40\V.MEM\PANDP\DVD2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\DVD2\PANDP\V.MEM" not found
    ERROR: [890] "ZONES\STANDARD\BEOVISION7-40\V.MEM\PANDP\V.AUX\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX\PANDP\V.MEM" not found
    ERROR: [892] "ZONES\STANDARD\BEOVISION7-40\V.MEM\PANDP\V.AUX2\SWAP" source_item  ABSD secondary target "ZONES\STANDARD\BEOVISION7-40\V.AUX2\PANDP\V.MEM" not found
    I don't know how to configure it correctly, I suppose that the problem is when choosing products but the changes that I make aren't saved.
    I would appreciate your help.
    (btw. Catalan, Spanish and English speaker)
  • 06-08-2009 9:58 AM In reply to
    Re: Problems with serialization and configuring P-and-P for all the fonts.
    Prior to entering the EDIT section it is likely you have deleted a needed function.
    As a general rule do not delete items, if they are unwanted then just hide them. The Beo5 Configuration Tool is not very good at deleting items successfully from a configuration without causing other issues.
    The quickest way to recover from this situation is actually to start the configuration again from scratch.
    Regards Keith....
