Hi!
The white pieces are made from the original, I used a mix of plastic resins and then adapted to fix in the cover.
To create this parts you need a vacuum box and a little furnace (temperature controlled), so if you need I can make for you the hinges; you pay only the delivery tax and little price for the materials, I don't want ANYTHING for the work because it's not my job (it is an hobby for my mind and a game for my son in the avatar ).
As usual, if you find someone that make this as a job ask him first! :)
The difficult is to find the proper resins mix to have the needed strenght.
Actually I'm working on to solve the problem to let the cover opened whitout stressing the hinges; next on this topic!
If you need you can contact me on msn
mastro_vintage@hotmail.it
I'll be very happy to help you
ciao ciao
Eugenio
