I purchased this MCP 5000 the other day, and got it to display a few things twice, but since then no luck.
The seller told me he suspected the contacts on the battery points, so I taped 4 D cells together, with a wire on each end and connected tehm directly to the positive and negative wires on the MCP 5000. This worked twice, both times very briefly but not since.
Does anyone see (in the pictures) or know what could be (or goes) wrong wit the MCP 5000?
*Note: If you right-click, and then select view image you will see higher res. versions of these pictures.
In image 3, there appear to be cracks in the middles of the transistors (?). All of them on the board have these cracks - is that hte probelm?
