Latest post 05-31-2009 9:16 PM by Dave. 5 replies.
Page 1 of 1 (6 items)
  • 05-31-2009 11:12 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    My beovision just skipped an important step when i switched it off!
    My BV3-32 just skipped it's electronic curtain when i switched it off (radio on BS4 playing independently). Screen switched off and TV parked, as the BC1 does.
    Has anyone had this happen?? I turned it back on, repeated exactly what i did, and the curtain then closed as normal... bizarre...
  • 05-31-2009 2:19 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: My beovision just skipped an important step when i switched it off!
    hmm. odd.
    I know that when you connect a HD BV5 to an HD Sky Box, you 'lose' the curtains function..  Software clash / override?
    Not sure what caused your issue though!  Anyone?
    Lee
  • 05-31-2009 4:36 PM In reply to
    hm... electronic curtain...
    Does BC1 have electronic curtain ?
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 05-31-2009 5:51 PM In reply to
    Hi Nikola,
    No BC1 does not have electronic curtain. Picture goes off and sound rapidly diminishes afterwards.(I have just acquired BC1). The Avant does. When the screen comes on the picture appears in the centre as a thin vertical line and then opens out to the wide screen. The sound gently comes on (and gently goes down as the curtains close when switching off.)  I think an earlier Beovision model actually had a physical electronic curtain with  shutters that slid from the centre to left and right.
    Dave: Sorry, can't help with the original query re step being missed. Coincidental loss of signal from a STB causing picture loss at same time as switching off?
    Vikinguk
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 05-31-2009 6:05 PM In reply to
    Hi Dave,
    just wondering why you mentioned you have the BS4 radio playing, is it linked?,
    as if you press radio linked through the BeoVision the curtains will disappear.
    another thought , it is possible to miss the curtains closing with an extra long blink Big Smile
    jason
  • 05-31-2009 9:16 PM In reply to
    • Dave
    • Posts 2,328
    vikinguk:
    Hi Nikola,
    Vikinguk
    On that note though, my BC1's sound fades in and out rather slowly on powering up and down. I'd be curious to know if anyones BC1 has electronic curtains, later versions had the option to have the 5.1 channel powerlinks at the back...
    If my set top box looses signal an icon comes up saying "no, or bad signal" It appears my BV3 glitched! As i said i repeated exactly the same with the beo 4, turned the TV back on, pressed AV RADIO and mute (so i can see the radio station on the screen), covered the tip if the Beo4 with my hand and pressed TV, then stand-by. Curtains worked as normal. Geeked
