1st March February 2012
Latest post 06-16-2009 9:22 AM by SWISS_2. 26 replies.
06-02-2007 7:10 AM
Oasis
- Joined on 05-13-2007
- Posts 109
Carry case for Beosound 3?
I have a beosound 3 and I think the sound quality is very good and I have always thought it be would cool to bring it to a picnic or take it with me on a weekend road trip...even though it's portable...I am always worried about scratching it... I don't think there's a carry care for the beosound 3 out there...but I think it would be a great idea...what do people think?
Stars
- Joined on 04-24-2007
- London
- Posts 1,483
Re: Carry case for Beosound 3?
You mentioned 'picnic,' I immediately brainstormed a Champagne cooler, would that do the trick during its journey in the car?
SWISS_2
- Joined on 04-16-2007
- Neuchatel, Suisse
- Posts 552
Hello Oasis; I think this is an excellent idea, and one that Bang & Olufsen could pursue. I would be easy enough and would serve to protect the looks and function of the BS 3. In taking the original " portable " Beosound 1 here and about, and having scratched two BS 1 grille covers over the past 5 years, you take chances with your investment. Replacement grilles are not an inexpensive item at Euro 175 + each, and some of the original colours have since become unavailable. The two that I purchased in Europe were later taken to North America and then on to South America. I cut 2 " thick Coolite (blown cellular styrene) foam into 4 patterns, and taped the sections over each BS 1 to carry it through as accompanied baggage. I did this as it was somewhat double safe inside a locked suitcase, than inside the original B&O carton alone. Also less obvious considering theft these days. This method works, and would also for the BS 3, but can be a bit of a mess at times opening and closing the packaging when taped. A good carry case, padded on the inside, and bottom, could utilise the BS 3 carry handle at the top. Until such time as B & O offers such protection, you might want to onsider the merits of using one of the Pelican Box models available in Sailing or Diving shops. These are light, water and dustproof, and thickly foam-lined. The foam inside pulls out, and can be cut to fit a BS 3 plus all cables, cords, and other accessories.You can see one of the cases here: http://pelican.com/cases_detail.php?Case=1500 Cheers
Stars
- London
- Posts 1,483
britops: A Louis Vuitton case?
LOL, both of you guys have made me seem incredibly stingy compared to my idea!
Oasis
- Posts 109
The LV version will probably cost more than the BS3 itself!!! What I have been doing is wrapping it with a thick towel/blanket...so the champagne cooler idea is not that stingy! I hope some manufacturers might read this and translate it into an actual product...since there are covers/cases for a lot of useless things on the market...
meandmyshadow
- Joined on 04-17-2007
- Posts 339
As with most B&O equipment the BS1 has a dedicated quilted product cover available for your dealer, they are produced for servicing use but I am sure that your dealer would be happy to sell you one. I am not sure if there is one for the BS3 but if you have a very helpful dealer, they will be able to see if one is available.
Tom
- Luxembourg
- Posts 3,175
Never heard of a BS3 carry case, but it would be a usefull item. The only problem I see is whether the sound quality would stay the same, as the speaker would have to be hidden by the case.
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Stars
- London
- Posts 1,483
tom: Never heard of a BS3 carry case, but it would be a usefull item. The only problem I see is whether the sound quality would stay the same, as the speaker would have to be hidden by the case.
I think Oasis meant a carry case for its travel, might be wrong.
Philippe
- Toulouse, France
- Posts 321
You can order the BS3 protecting cover at your dealer under the B&O piece ref : 3375489 Here's the link (thanks again PL212) to the various B&O product covers. Philippe
Tom
- Luxembourg
- Posts 3,175
Henry: tom: Never heard of a BS3 carry case, but it would be a usefull item. The only problem I see is whether the sound quality would stay the same, as the speaker would have to be hidden by the case.
Ok, now I understand...
waltoninn
- Joined on 06-04-2007
- USA
- Posts 21
When I was looking to purchase the BeoSound 3, I also tried to anticipate finding a case for it. So, I looked into getting a Mulholland Brothers Deco Single Wine Carrier Case. The measurements seem to be right, but I wasn't sure how the handle would be positioned. You can see the details of the case at: mulhollandbrothers.com If you try it, and it works, please let me know, because I would be curious to find out if it is suitable. And you should know that Mulholland makes very good quality leather goods. Good luck!
Stars
- London
- Posts 1,483
Turns out my brainstorm was a good idea: PERFECT! Available on Amazon.co.uk for £16.99. Only 3 left lin stock, so hurry and buy your new limited edition innovative aluminium Bang & Olufsen BeoSound 3 travel case with shoulder strap now!
SWISS_2
- Neuchatel, Suisse
- Posts 552
Good looking case. Price is also very good, when compared to Rimowa. Will it fit correctly with the top handle ?
Stars
- London
- Posts 1,483
SWISS 2: Good looking case. Price is also very good, when compared to Rimowa. Will it fit correctly with the top handle ?
Please don't tell me you've already bought one! I meant it as a bit of a joke, however if it does fit then why not? Does anyone have the dimensions of the BS3? I'll check up on the dimensions of this splendid travel case in the mean time.
Stars
- London
- Posts 1,483
eduard: Well it is true, after some months I got a new one from my dealer.....and that one is okay!!
Oh it was a faulty one. I understood they made them all the wrong size! You make me laugh Ed!
SWISS_2
- Neuchatel, Suisse
- Posts 552
Henry; Yes, I already did, but like B & O, this is also long-term ongoing collection. The Lufthansa Rimowa model Bordkoffer ( or onboard box case ) works, as does the Attache. It fits, but still requires some padding around it. I have this from 1994. Rimowa being around for 100 + years , has made a box for just about everything or size imaginable. There was, or still is a Champagne case offered, that was padded and opened in a split-side hinged manner, with a lock. I like good Champagne, but I never quite saw the need for it. . I think the case shown above is the right choice for the price, looking quite smart, but perhaps a bit flash to leave in the backseat of a car. Polished Alu, Stainless Steel, or even Silver metallic paint always attracts the eye. I one had a BS 3 inside, I'd keep it hidden and protected in the boot.
Stars
- London
- Posts 1,483
Hi Swiss, It just occured to me that the handle wouldn't fit inside the case I attached above because it sticks out so much on the sides. The case also doesn't have any padding inside so you'll probably scratch the BS3 every time you put it in and out. That post was all a bit of a giggle really, and just to prove (probably just to myself) that my first post in this thread was almost a brilliant idea. I'll have a further look around on Amazon and see if I can find anything. Maybe Eduard will also be able to tell us how much he speant on his B&O case?
SWISS_2
- Neuchatel, Suisse
- Posts 552
Thank you Henry; I looked at the links: You done quite a bit of homework searching around. Something came to mind about the last one. Sure enough, sitting deep in the sideboard was one in Burgandy we received as a gift 4 years ago. Never been used, and just sat there. I pulled it out, and yes, it almost fits. The handle juts out a bit. My concern is dings, dents, and internal damage if it were bounced around driving. But it would work as a light, neoprene soft cover. Just an aside you might find interesting regarding some previous discussion of single speaker sound quality with the BS 3. Some have mentioned that the BS 3 isn't comparable to a BS 1, and this is correct as the two are different units entirely. However, I just pulled a couple of old Zenith Transoceanics tube " portables " out to compare with the BS 3. Both radios were considered " The Ultimate State of the Art " for their time. One unit is a G 500 (1948) the second is a H600 (1954) covered in brown leather. The first two very retro looking radios: - weigh 31 + pounds each without batteries,
- have shortwave, and AM band only ( Frequency Modulation channels didn't exist yet for civilians )
- a single small speaker
- a lighted " slide rule " dial ( seen in later B & O models )
- no digital anything
- no alarm clock
- combination of a 5 foot telescope antenna.and 2 pound " wavemagnet " antennae
- you listened to what you could find on the airwaves, not what you wanted to.
Which of the three is lighter, plays FM, and digital recordings, and sounds better ? Another good reason to protect your investment with your BS 3, which has come a long way since those days. One might argue that the MP3 formats are smaller, but you can't share an MP3 player with a crowd like you can with a BS 1 or 3.
