Latest post 05-31-2009 8:57 AM by hampeman. 2 replies.
Page 1 of 1 (3 items)
  • 05-30-2009 8:32 AM
    STB Sagem DTR94000 TA HD
    Hello out there,
    I have a BV 8-32  connected with a STB Sagem DTR94000 TA HD. It works fine together with the Beo4, but the sound in the BV is very  low. Of course I can turn the sound higher on BV8, but with a lot of noice. Does anybody know if it is possible to adjust the sounds level in STB?
    Edde
    Filed under:
  • 05-30-2009 8:48 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: STB Sagem DTR94000 TA HD
    Should be possible. You have to use the Sagem remote and set the output level of the stb to maximum. Now you can control the stb level with Beo4 via your Beovision. Hope this helps.
    Stefan
  • 05-31-2009 8:57 AM In reply to
    Thank you
    It works
    /E
