Latest post 06-15-2009 9:53 AM by Large48. 10 replies.
Page 1 of 1 (11 items)
  • 05-29-2009 6:05 PM
    MX 4000 questions
    Hi guys:
    I have an MX4000 and wall stand which I have just purchased for my mother-in-law. My initial impressions are that it is yet another lovely looking set from B&O yet I think the LED/reciever unit placed in the top right hand corner of the set detracts from its overall appearance.
    I am planning to mount this on the wall yet I don't have any screws. Could someone tell me (I am a novice at DIY) what size, type and name of screws I need, what size drill bit I need and what kind of rawl plugs. It is to go on an internal - i.e. not exterior brick wall but it is not plasterboard. The wall is of Victorian construction so I do not know if breeze blocks were invented back then.
    Also I note that some stands had a slot for a video or sky box - this is not immediately apparent to me - is there a extra bit I need to bolt onto my stand or was there a specific stand that had this slot and if I don't have it, I don't have it?
    Graham
  • 05-30-2009 5:12 AM In reply to
    Re: MX 4000 questions
    I suggest that you take the stand into Mackays in Cambridge and ask them. They can provide you with everything you require.
    Regards Graham
  • 05-30-2009 5:20 AM In reply to
    Hi Graham:
    Thanks, never thought of that, this would be the easiest and most fool-proof solution.
    Graham
  • 06-13-2009 5:11 PM In reply to
    Hi all:
    My MX4000 is now sitting on the wall as planned. It does not have ML (were any of them equiped with this). This therefore brings me onto my next question:
    If in the future I picked up an Ouerture or something simillar, could this be conected to the TV thus utilising the TV speaker. Also, could I then get a wireless speaker (B&O or other) and place this elsewhere in the house with a link eye thus creating a basic multiroom system?
    Graham
  • 06-13-2009 5:18 PM In reply to
    Edit:
    I barely understand the difference between powerlink, datalink and masterlink, indeed I only just remembered the term datalink. As far as I am aware, powerlink is for connecting speakers, I know nothing of datalink. masterlink carries Audio signals and coupled with a RF cable, transmits video also. I have checked around the forum but the other posts either only touch on the subject or confuse me further. So, is my proposal possible with a non ml MX4000?
    Graham
  • 06-14-2009 3:28 AM In reply to
    Hi you need a beolink module (I cannot think which one), From this you will be able to access the overture. To be honest. I would look for a set with masterlink (like a 4002 or 4200 they look nearly identical to yours).
    Or you could go for a beovision 1 as they have the active speakers built in!
    Hope this helps
    Cheers Nick
  • 06-14-2009 6:31 AM In reply to
    Hi:
    Thanks I have a Beovision 1 myself but could not really afford to get her one of these. I understand that the sound quality of the MX4000 I have will not be as good as say with a Beovision 1 but until I can afford to upgrade the MX4000 for her you suggest I need a Beolink module. I am unsure what one of these is, however, I hazzard a guess at it being one of those control boxes that is mounted into the wall and forms part of a multi-room system.  I think in the short to medium term this is my best option. Could anyone shed some light on doing this?
    Graham
  • 06-14-2009 7:11 AM In reply to
    You should have bought a MX4002 in the first place. There was one for sale about 20 miles up the A10 from you!!
    Now you need a Beolink Converter Type 1611, a masterlink cable and an audio aux link cable and you will hear Ouverture sound in the MX speakers.
    Regards Graham
  • 06-14-2009 1:27 PM In reply to
    Follow on question about the wall bracket though....
    Did they ever do an addition (shelf?) to it so you could attach a vid/dvd/stb etc etc?
    Cheers
    Train Hard - Run Fast - Hit to Kill!!!
  • 06-14-2009 1:57 PM In reply to
    Large48:
    Cheers
    No, they didn't!
  • 06-15-2009 9:53 AM In reply to
    Sounds like a market out there for someone (cough STB, cough Sounds Heavenly) to come up with a suitable add on........
    Put me down for two!
