Yes, I know this must be a FAQ, and I searched the forum and found the answer.
The thing is that the trick doesn't work with this Beomaster 7000 I have here. I did exactly as described:
- added V.SETUP to Beo4
- turned the Beomaster on radio
- went to another room to click TV on Beo4
- returned and LISTed to V.SETUP
- clicked on GO, Beo4 shows TUNE
...and absolutely freaking nothing happens. I can press all the arrows and numbers I want and the Beomaster doesn't react to any of them (and the dot doesn't flash).
Can this be a software version issue or something else? Not a big problem anymore since I will make another trip to set it up, this time with a recharged BL7000, but would still like to know what this means...
