>Isn't the problem at present that you can't watch and record different (digital) >channels at the same time, since the tuner inside HDR1 and 2 is analog?
Yes, that is true
>How about pausing the live TV?
I do not think that it works
>Do you need to "pair" the BV8 and HDR1 or do they just work together as you >expained when connected to BV8-40?
No, you just connect them. It is a 7-40, not that it makes any difference.
>Is the "Record" - button in Beo4 in use?
Yes, that works. Just press "Record" twice and the recording starts.
So all in all it is a mixed bag of pro's and con's. The ideal would of course be a recorder with a HDMI interface, but I do not know if it exist.
I think I will keep my Samsung box from the program provider as it has a harddisk that records in HD quality and the ability to see one program and record another.
That means that I will not need the DVB-HD and the HDR.
