Latest post 05-29-2009 3:53 AM by 9 LEE. 1 replies.
Page 1 of 1 (2 items)
  • 05-27-2009 5:41 PM
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    A Big "Thank You" to Keith Saunders and also to the rest of you
    Hi All,
    Just would like to take this opportunity to say a big thank you to Keith who has helped me and many others to gain an understanding of 3rd party programming for the Beo5. Never knew anything about xml until 10 days ago until Keith inspired me to have a go.
    Just have spent an entire weekend programming for a 3rd party product (which has been uploaded) and it works wonders!!
    This wonderful site and its contributors are constantly improving my enjoyment of Bang & Olufsen products so an additional thank you to you all.
    My tip of the day (for what its worth!!) is study the template for the  HP Windows Media Centre. IT  has all the elements within  to learn how to program for a 3rd party product (including digits, plus hard and soft keys).
    Just two questions,
    1 What recommendations are there for xml editors and tutorials  to use to improve  beo5 3rd party pogramming?
    2 Is there a list of the xml tags and their definition for which the config tool uses?
    Good evening
    StUrrock
  • 05-29-2009 3:53 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: A Big "Thank You" to Keith Saunders and also to the rest of you
    What can we say?  Keith is a genius and an incredibly helpful guy too...  Not only with the Beo5 config either - he does heaps behind the scenes to keep this site running smoothly that nobody sees.
    Yes -  thumbs up
