Latest post 04-05-2008 4:19 AM by joeyboygolf. 9 replies.
Page 1 of 1 (10 items)
  • 06-02-2007 3:55 AM
    "Old" Beo4 and A Mem
    Any one know how you achieve A Mem on an old Beo4?
    Regards Graham
    Filed under:
  • 06-02-2007 4:02 AM In reply to
    Re: "Old" Beo4 and A Mem
    Sorry, got it. SHIFT / A TAPE
    Your technical advisor was having a Saturday morning moment!!!!Sleep
    Regards Graham
  • 06-02-2007 4:53 AM In reply to
    Isn't A.MEM the same as A.Tape. I thought SHIFT, A.TAPE was A.TAPE2?
  • 06-02-2007 7:51 AM In reply to
    Quite correct Peter, just wanted to see if you were concentrating!Wink
    Regards Graham
  • 04-04-2008 6:31 PM In reply to
    Hi Graham...
    There is no "shift" on the beo4 i've got here.......
    How do i get there??
    gracias..
  • 04-04-2008 7:09 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Keith, do you know how to 'ADD' to your list?
    Poor me, never win owt!
  • 04-04-2008 9:01 PM In reply to
    Hi Andy...
    Well i read the manual...for the BEO4....but never done it..
    So...  Hold down the (RED DOT) and LIST ....then...release both....then
    press LIST until i see ADD?........then....(this is where i get lost)...
    Would really appreciate the rest to get to "SHIFT"...and how to use it to go into TEST MODE for a BS 9000..
    gracias!!
  • 04-05-2008 4:14 AM In reply to
    • Jandyt
    • Posts 13,004
    Hi Keith,
    once you see 'ADD', press 'GO' then list intil you see what you want to add, in your case, 'SHIFT'
    You can now either press 'GO' and shift will be first on your new list,  or a number eg 3 and 'Shift' will be third on your new list.
    Hope this helps.
    Andy T.
  • 04-05-2008 4:19 AM In reply to
    Now you know why most B&O engineers carry a Beolink 1000 and I have one on my workbench!!
    Regards Graham
