1st March February 2012
Latest post 08-12-2009 6:06 PM by LifeStyle. 90 replies.
05-26-2009 2:40 PM
windmacher
- Joined on 04-05-2009
- Posts 72
At frist come 40inch sizes... later bigger sizes
@ all
has anybody informations or pictures about the design of the BV10....
koning
- Joined on 04-16-2007
- Netherlands
- Posts 2,670
moxxey:
But I'm assuming this 'wonderfully engineered' BV10 won't come with a BS3. So it's basically a BV8-40 in a new shell?
It wouldn't surprise me
Michael
- Joined on 05-20-2009
- Glen Waverley, Victoria, Australia
- Posts 245
What's a BV-10?
Regards
Michael.
koning
- Netherlands
- Posts 2,670
So,
The only difference is the glass-plate and led-technik.
What about the sound?
Is it better?
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
mbee:
Same chassis doesn't mean same number of connections : let's hope they put a 4x1 switch in the BV10 instead of the 2x1 of the BV8...
Do you really believe that? The BV10 is supposed to be mega-thin. I wouldn't be surprised if B&O *reduce* connections. Hell, they can't get the RF box in to the back of a BV9 or BV7-40. How would they get a HDMI switch in to an ultra-thin BV10?
Unless B&O drastically change their engineering ethos, I don't see how this is going to happen.
TripEnglish
- Joined on 10-27-2007
- America
- Posts 1,595
Maybe it will have a socket panel!
Seriously, though. If B&O has taught me one thing over the years it's that regardless of the number of connections they'll see to it that you can only connect 75% of them and still be able to fit the back cover on it.
There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
Sal
- Joined on 04-30-2007
- Indianapolis, USA
- Posts 261
TripEnglish: Maybe it will have a socket panel!
The socket panel was one brilliant idea. I hope they do consider it as a standard from here on in for almost every product. I remember stretching and contorting with a flashlight to install my old Avant, and the BV8 wasn't all that easy either... Makes me glad the Beosound 9000 isn't all that difficult compared to those two beasts.
Sal
Love B&O, but no longer addicted.
leogenghis
- Joined on 12-08-2008
- Posts 169
Is "socket panel" the large metal plate on the rear of most A/V products with red, white and yellow connections? If so, then I prefer stretching and contorting myself to fit the back cover on. B&O should design their products to look good from the rear, too!
The BV 10 is a slimline TV meant for wall-mounting, so socket panel might work in this case.
Leo
BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
moxxey
- South West, UK
- Posts 2,360
Sal: The socket panel was one brilliant idea
Sure....if you can hide it! The Beocenter 2 has a huge socket box and there's no-where for me to hide it. As most Europeans rent their apartment/house, you can't always go digging up the floorboards or hiding it in a wall. My BC2 socket box is on the wall for all to see.
TripEnglish
- America
- Posts 1,595
avus17:
My dealer told me that BV 10 would not look like BV5/BV) with thin frame but it will have speakers on each side of the screen. It will also have a contrast screen. I am not sure about design, perhaps we all expact to much. Still the best designed TVs from B&O would remain BV7 and BV4+9 for a lot of money:=(
Your dealer fibbed to you. It looks like a BeoVision 5 with BeoVision 9 proportions (i.e. the speaker is not equal to the screen). The frame is also considerably thinner around the entire piece. There is no acoustic lens. For 9 out of 10 people it will be so close to what you're imagining that you'll think you have psychic abilities!
It looks VERY sexy!
Beofan2
- Joined on 07-31-2007
- Fredericia, Denmark
- Posts 313
Roger:
Think of a slimmer (less bulk, less frame) BV5 mounted on the wall...
Roger
My dealer confirmed it today. He will see it in the beginning of september. Looking forward to further information. Sounds like a great new BeoVision.
It´s not magic - it´s Bang & Olufsen
LifeStyle
- Joined on 04-01-2009
- Posts 97
Has anybody an idea if the BV 10 will get the BS3 and/or a Blueray drive?
It would also be interesting if it will be a LED TV?
I am not sure if the BV 7-55 is exactly the same as the BV 7-40: It should be possible to put a HDR2 into it, it sould be a LED TV, and it should have a similar motorized stand as the BV 4-103....
