Latest post 05-23-2009 2:49 PM by jacob79. 5 replies.
Page 1 of 1 (6 items)
  • 05-22-2009 12:38 PM
    Beovision7-40 VGA connection, but where can the sound be connected?
    Hi
    I am trying to connect my Mac Mini to my Beovision7-40.
    I have connected it to the VGA connection on the Beovision7-40, but do anyone know who I connect the sound on the Beovision7-40?
    Best regards
    Jacob
    Filed under: ,
  • 05-22-2009 1:22 PM In reply to
    Re: Beovision7-40 VGA connection, but where can the sound be connected?
    That is a good question, and I did not find it.
    But also if I try 1920x1280, the screen remains dark. What resolution did you adjust?
  • 05-22-2009 2:27 PM In reply to
    I only think below resolutions are supportet.
    VGA, 60 Hz, 64 0 × 48 0, 848 × 48 0, 1024 × 576,
    800 × 600, 1024 × 768 , 1366 × 768 og
    1280 × 720.
    But it is very strange, regarding the sound I do not belive that they have made a solution for computer vga connection but without sound supported.
    Best regards
    Jacob
  • 05-22-2009 3:15 PM In reply to
    I solved the problem by buying the Apple TV. I know this doesn't answer your question as such because you still want to connect the MAC mini but I can tell you that the ATV is a great piece of kit and will do everything you want. If not, hacks are available for it.
    Simon.
  • 05-22-2009 4:00 PM In reply to
    • rhone
    • Not Ranked
    • Joined on 04-17-2007
    • Dublin Ireland
    • Posts 10
    I have the sound from my PC connected to L-in and R-in on the AV 5 output in my BV-40 ,the sound works fine might try spdif next to see if gets any better .
       Rhone
  • 05-23-2009 2:49 PM In reply to
    Hi Rhone,
    Thanks, that worked.
    The only thing is that I used AV5 for my satelite recieve which only have the yellow, white and red cabel. But I will use a scart converter for that instead.
    Best regards
    Jacob
