No standby LED?
Then either the fuses are defect, there are 2 of them... 1x for the standby transformer and 1x for the power amp.
Check with an ohmmeter wether there is some resistance on the power cord, there should be something around 300 Ohms. If there is a open loop, then the fuse or the standby transformer is gone...
