Latest post 05-22-2009 9:27 AM by jk1002. 1 replies.
Page 1 of 1 (2 items)
  • 05-22-2009 1:40 AM
    Beocenter 2 and surround sound
    Does anyone know if it is possible to connect rear loudspeakers to a Beocenter 2. Will there be surround sound, or do I need a decoder?
  • 05-22-2009 9:27 AM In reply to
    Re: Beocenter 2 and surround sound
    You need a decoder, typically a Beosystem 1, 2 or 3.
    If you do a search, there is quite a few discussions about how to pull this off best, especially if your rears are B&O speakers as well. You need a receiver with regulated line output so that you can control the volume of the speakers ..... also, you need to supply them with a control power so that they dwon't switch off automatically.
    Cheers
    JK
