Latest post 05-23-2009 6:04 AM by gbsub. 7 replies.
Page 1 of 1 (8 items)
  • 05-21-2009 6:24 AM
    link problem
    I have a Beocenter 9000 linked to an MX7000. Using my remote, i set both to option 2. The problem I'm having is that they both respond to one click of the remote as two clicks eg when I want to skip one track on a CD it skips two tracks. Anyone know what I'm doing wrong? Have I set the wrong options?
    Also, what is L option? (V option is Video an A Option is Audio)
    My B&O: 2009 Catalogue and Pricelist
  • 05-21-2009 6:31 AM In reply to
    Re: link problem
    If they are in the same room, they should both be in Option 1.
    L option is for link dedicated products (Beolab 2000, 3500...)
  • 05-21-2009 6:48 AM In reply to
    Re: link problem
    Hi Phil,
    Thanks for your response. I set them both to option 1, and still the same problm. When I remove the cable between the two, all operates perfectly as normal. Odd huh?
  • 05-21-2009 7:01 AM In reply to
    Re: link problem
    Have you verified that the Red led blinked when you changed the V.OPTION and the A.OPTION to 1?
  • 05-21-2009 7:02 AM In reply to
    Re: link problem
    There must still be something wrong - in option 1, the audio/video products should not send the commands further to each other on the AVL cable (which is happening when you get duplicates), and only respond to their "own" commands.
    I suggest you reprogram the options, and keep the other kit disconnected from mains while doing it (not sure if it affects anything, but I'm superstitious that way...).
    -mika
  • 05-21-2009 8:45 PM In reply to
    Re: link problem
    .... no luck. I tried both ways and still have the same problem. Sad
  • 05-22-2009 3:22 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: link problem
    Try setting both to option 1.5
  • 05-23-2009 6:04 AM In reply to
    • gbsub
    • Not Ranked
    • Joined on 05-23-2009
    • Posts 1
    Re: link problem
    you must setting the Bs 9000 as A.OPT 0 and the MX7000 as V.OPT 2.
    This is the only right way.
    Best regards.
    gbsub
