Hey there
I have a beocom 6000 mrk2 connected to a mrk1 base, conected to IP phone, which have worked perfect for about 3 years, but now the mrk2 handset, is making trouble... It startet one day where the phone ring, but i was not able to answer the call from this handset, the textdisplay says "slukker" (Means turning off), after this, i can only get the phone to work for a short time (differ) by turning off by holding "OK" down for 10 sec. and then turn on again...
The old mrk1 phone still works perfect!!! (Same Base!)
I have tryed to:
disconect the battery for 36 hours - no changes
change the battery between the to handset - no changes
Reset the Handset by 9#9#9*INT reset hanset - no changes
disconnect/reconnect the handset - no changes
Called B&O costumer support - actually no further help, than go to your local dealer!!!
Search in this forum and google the problem, without any luck
Please, can somebody help???
Thanks a lot for your answar/help
Bjerring
