I recently had the firmware of my MKI BeoCenter 2 updated with the most current firmware. Early firmware versions were prone to DVD chapters skipping back and replaying. This is corrected with a firmware update. Another improvement is the picture quality! Connected to a Beosystem 1, the BC2 DVD playback had very jagged artifacts. The picture is MUCH better after the update. The update also removed the annoying "GO, GO" requirement whereby we had to press "GO" after every command for the command to be executed. I did notice that with the firmware update the BC2 now corresponds with the "BeoCenter MKII" on the PUC rather than the "BeoCenter MKI." That is, the blue button is now used for disk menu rather than the yellow button. The firmware update still did not enable divx playback, however.
It's so nice to now have single button commands on the remote.
I thought this information would be good for other BC2 owners to know.
