Latest post 05-20-2009 5:41 AM by tournedos. 1 replies.
Page 1 of 1 (2 items)
  • 05-20-2009 5:21 AM
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    set top box from other country?
    Hi will a set top box from germany work in australia?? I'm desparate to know, i need to find a set top box that is in my BV3-32's memory for controlling it>>>
    I'm struggling to live with my two TV's that have STB-c's but do not control my set top boxes!
  • 05-20-2009 5:41 AM In reply to
    Re: set top box from other country?
    For terrestrial broadcasts, Australia is using DVB-T transmission standard just as Europe and South America. However, the problem is that the standard doesn't cover all details like the actual frequencies that are used (a "localized" tuner might not reach all frequencies you'd need), the compression method (MPEG2 now, but might change) and the software in the box itself may need localization to fully support the transmissions. For example, there are at least two methods of subtitling, and Germans typically don't use either of them (but dub instead Ick! ) and that feature might be bug-ridden due to lack of use. Encryption methods are also quite localized and you probably would not be able to view any pay-TV channels with an imported STB.
    To put it short, I think so, but probably not fully - hope this is more clarifying than confusing! I guess the only way to know for sure is to try it...
    -mika
