Hello,
I need your advice about the cable type I will need to connect the Beovox 4500 Speakers to a MCL2P or a Beocenter amplified unit (8000/9000/9300)
Would you please let me know what cables should I use ? The Speakers have just two leads that can be connected by inserting rough wires. As I have seen in pictures the units(which i don't have by the way ) have special terminators with three pins positioned in a triangle form.
I have attached an image in order to be more clear.
Many thanks for your help.
This forum helped me a lot.
Stefan
