        1st March February 2012
	    Latest post 05-20-2009 11:34 AM by  Peter. 8 replies.
								        05-19-2009 3:48 PM
									        Dennis
								                - Joined on 02-01-2009
								                - Denmark
								                - Posts 172
Hi there
I have just replaced af piece in my Beomaster 3500, and now the display shows CODE. Does anyone know that code? I hope that you can help me. It would be great, if you that have replaced your SW still have the code.
Best Regards
Loudspeaker
									    I was borned with a Beolink 1000 in my hand!
Ever seen a Beomaster 6001? I have one! Look here.
Main system: Beovision AV9000, Beocenter 2300, Beosystem 3500, Beolab Penta MKIII, Beolab 3000, Beogram 6500, Beolink 1000, Beolink 5000, Beolink 7000
Wish list: Beolab 2,
									        Dillen
								                - Joined on 02-14-2007
								                - Copenhagen / Denmark
								                - Posts 5,008
										    Sad case.
I suppose you could try putting the Beomaster in TEST mode and then press 7. That will load default values into the RAM (if it works in your Beomaster).
What did you replace and why ?
									        Dennis
								                - Denmark
								                - Posts 172
										    I have 2 Beomaster 3500 so mayby i can take some parts from that. I have replaced the software with another. I will try to call a B&O repair shop today and find out if they have a code, beacause i think that there also must be activatet a code when the Beomaster 3500 is finished on the factory. I have also read that Peter Pan had his Beocenter 9300 to repair, and when he had it back from the repair shop, it wasn't working because the code wasn't entered after replacing something.
Best Regards
Loudspeaker
									        Dennis
								                - Denmark
								                - Posts 172
										    Hi
That is the same code than for Beomaster 4500 and Beocenter 9500 and mayby then also for Beomaster 3500.
Ignace wrote:
I can't think of another code than the one Peter mentioned in the other topic :
- power off on Beomaster (disconnect from mains)  - on Beolink 1000, press RADIO  - plug in Beomaster 4500 (connect to mains)  - press 1271 PLAY on Beolink 1000
I will try the code when i come home. I hope that it works :)
Best Regards
Loudspeaker
									        Dennis
								                - Denmark
								                - Posts 172
										    I tried to enter the code 2 times, but there was no respons, so i tried to connect it to my Beovision LX5500 and then the CODE sign was gone and then the Beomaster 3500 was working :) I don't now if that was the code but it can be that there wasn't any respons caused of, that the Beomaster was in option 0. The Beomaster is also working without Beovision :)
Thanks for the help :)
Best Regards
Loudspeaker
        Page 1 of 1 (9 items)
