Latest post 06-03-2009 12:36 AM by jk1002. 3 replies.
Page 1 of 1 (4 items)
  • 05-19-2009 8:32 AM
    • Klas
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Singapore
    • Posts 96
    Eureka; aTV now controlling beoport - limited usage but just so its out there
    hey guys; just to let you know that my 1wk project finaly gave results and i'm now able to run my aTV with Leopard OSX (so the aTV is now like a mac mini rather than aTV's limited SW that you can't install BM-Link on)
    While i expect there are very few out there who would be intresting in hacking an aTV and run OS X - i at least wanted to let you know its possible as i did my research in this forum prior and didn't find any answers....
    If you need any help or have any questions - let me know.
    Objective:
    Wanted to be able to use my spare BL 7-1 as a bedroom speaker which i could play music and controll with Apple touch/iPhone remote without having to buy the full MacMini which would be pearls for Swine as no video/performance required.
    Challenge:
    BL 7 doesn't have a line-in (so no external DAC e.g.) - hence needed to use the BeoPort - which requires BM-Link software that can't be installed on aTV (which i'm sure is possible, i just don't have the UNIX skills to do so - just preservance)
    Solution:
    Aquired the smallest 40GB aTV
    Installed Leopard OS X (as per instructions on Hackintosh)
    Installed BM-Link SW
    iTunes, Server mount automatic on log-in
    Apple Remote SW paired with new iTunes
    all the best
    Klas
    Grant me the serenity to accept the B&O I can't afford
  • 05-29-2009 8:16 PM In reply to
    Re: Eureka; aTV now controlling beoport - limited usage but just so its out there
    sounds fantastic !
    have you noticed any performance problems ?
    [ I wonder what the chip difference between an AppleTV and a Mac-mini is .... ]
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 06-02-2009 4:45 AM In reply to
    • Klas
    • Singapore
    • Posts 96
    havent played around so much other than with itunes - but i tried internet browsing etc and it worked fine......if you stick to basic tasks the processor is fine.....
    Depending on what formfactor and usage youre looking for; it seems that the new Dell Mini 10v is the best bang for buck and that runs hackintosh without any issues (you can also run win 7 RC1 for free as a virtual machine - so you get two OS's for a very very competitive price)
  • 06-03-2009 12:36 AM In reply to
    The chip difference is significant. I am running a media center software on my ATV, it breaks for certain video streams over the internet.
    I still would consider the ATV as it is truly designed to run without mouse and keyboard, the Mini will ask for one every know and then.
    Cheers
    JK
