Latest post 06-26-2009 6:58 PM by ouverture. 8 replies.
Page 1 of 1 (9 items)
  • 05-19-2009 12:45 AM
    Compatibility of BeoSound 9000 and B&O RL7000 Passive Speakers
    Trying to get some inputs as to compatibility between the BeoSound 9000 with the last generation of B&O's older Passive Speakers RL7000?  I understand the BeoSound 9000 works fine with the newer generation active speakers that have a different cable socket, but can the unit interface with the older passive speakers?
    Filed under:
  • 05-19-2009 2:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: Compatibility of BeoSound 9000 and B&O RL7000 Passive Speakers
    Hi and welcome to Beoworld.Smile
    The RL7000's aren't really compatible as main speakers as they will need either a Beolink Passive or MCL2P converter to power them from the BS9000 - they won't simply plug into the Beosound 9000. These converters are really intended to be used to power smaller link room speakers in a multi room set up and would probably not get the best out of the 7000's.
    Chris.
  • 05-19-2009 2:27 PM In reply to
    A far better performing - and contemporary - amplifier to drive the RL's would be a pair of Beolab 150/200's. But finding that pair in good condition might be a task in itself! (and IMHO they would look utterly silly together Wink )
    -mika
  • 06-11-2009 11:44 AM In reply to
    BS9000 + RL7000 Speakers + Beolab 200 mono amps
    I know someone who has a Beosound 3000 working very nicely with a pair of RL7000 speakers, the BS3000 have powerlink cables, and between the BS3000 and the RL7000 are indeed a pair of Beolab 200's -  it does not look silly at all, because the BL200 amps are hidden away behind the sofa in his lounge, and his RL7000's are wall mounted and sound super :-)
    It sounds just as good if not better than another friend of mine who has the BL8000 and BS9000 combo, which is still a popular choice !
    I will see if I can organise a bake off this weekend between both the RL7000 and BL8000 speakers at my house, and try out all the following combinations :
    RL7000 + BL200 + BS9000
    RL7000 + BL200 + BS3000
    RL7000 + BL200 + Beosound Ouverture
    then this set of powerlink combinations too  Stick out tongue
    BL8000 + BS9000
    BL8000 + BS3000
    BL8000 + Beosound Ouverture
    NB I have a pair of RL140's, but they need repairing before being subject to listening tests like the above I feel
    Peter
  • 06-11-2009 12:33 PM In reply to
    Re: BS9000 + RL7000 Speakers + Beolab 200 mono amps
    Actually the Beolab 200 was designed as much for the RL7000 as anything else. It can be used as a booster amp with older systems as well and is a super product. The actual electronics are not of the very best quality but they work together extremely well.
  • 06-12-2009 10:16 AM In reply to
    yes the 200's do seem to be the right fit, I wish a had a pair to use with my Ouverture, then I could hang my RL140's on the wall in the lounge and have the room booming with 140 watts of pure B&O sound  :-)
  • 06-26-2009 4:48 PM In reply to
    well interestingly we had quite a fun afternoon today at my house, we did a lot of listening to the following B&O kit, and some Wharfedale Diamonds, and we marked our scores out of 10, there were 5 of us, all between the ages of 36 and 52, I have added up the scores for all 5 of us, and these were remarkably consistent.
    SCORE
    72       RL7000 + BL200 + BS9000
    68       RL7000 + BL200 + BS3000
    69       RL7000 + BL200 + Beosound Ouverture
    74       BL8000 + BS9000
    71       BL8000 + BS3000
    70       BL8000 + Beosound Ouverture
    and the wild card, the Wharfedale Diamond 8.2 Active monitors
    86       Diamond 8.2 + BS9000
    85       Diamond 8.2 + BS3000
    85       Diamond 8.2 + Beosound Ouverture
    maybe the BL8000's are not all that they are cracked up to be  :-(
  • 06-26-2009 5:32 PM In reply to
    Not surprised at all. Would have been interesting if you compared the diamonds with a pair of good box speakers - something like some S120s or even M100s would show the Diamonds what real bass was like! Having said that, I use BBC LS3/5As with AB1 sub woofers in my main system and prefer them to most B&O speakers. Column speakers are always a compromise, even the lovely 8000s - I'd be interested to know what you would have thought about Beolab 3s. Speakers are very much a matter of taste - I don't expect people to always like what I like!
  • 06-26-2009 6:58 PM In reply to
    and a Beoworlder reminded me of this thread which reminds us of the BL8000 versus Redline 60.2 debate
    http://forum.beoworld.org/forums/p/5593/40645.aspx#40645
    my friend with the Diamond 8.2's does have a Wharfedale woofer at home, so I knew it would be unfair to the BL8000's if he brought it along today
    I love the Beolab 3's,  they are what I want to go with my Ouverture, the 3's look great on stands either side of any of the B&O family of products with the glass doors opening, much better than the BL2500 ( which was the normal setup back in the nineties )
