Someone messaged me a while ago about cable sock.... or cable tidy. Whatever you call it. Does anyone know where I can get this at a decent price ?
I couldn't see any at Sounds Heavenly. :-(
There is some available on eBay:
http://shop.ebay.co.uk/merchant/beotidy
Ian
what you are looking for is called "snakeskin", normaly available in various diameters. its used mainly in professional touring and available in most good music stores.
check http://www.toursupply.co.uk/contactus.htm for order info...
cheers
Hi Luke,
Good idea, I will try to get something suitable into stock asap.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Steve that is great.
We just bought all new cables from you !
"The rubber tube packed with the speaker is a cable cover specially designed for the BeoLab 8000"
Does anybody know where to buy Beolab 8000 tubes?
Do you mean something like this? I use it in my BL8000 in black
Quim
No. One of these:-
Does anyone have a pair for sale or know the product number?
You can by cablesocks cut at the length you want at http://www.danishsat.com/view_item.php?item_id=156
dk1: You can by cablesocks cut at the length you want at http://www.danishsat.com/view_item.php?item_id=156
Their shipping costs to Switzerland, from Spain start at 27€ bwahhhaaaaa. They must be joking.
